magosak Posted March 4, 2012 Share #21 Posted March 4, 2012 Advertisement (gone after registration) I got my 28mm and 50mm Summicrons and currently saving for a M9. As a novice in street photography, I find your recommendations very useful. I'll be sure to keep them in mind. Thank you. I would suggest the following - 1: Use a 28mm or a 35mm lens for your street photography. If you don't have either, shop around for a nice used 28mm f/2.8 elmarit. They can be bought for around $950US. A more economical but not wide angle alternative would be the 50mm f/2.8 elmar which can be had for $500-600US. 2: Get CLOSE to your subjects. If you are photographing a single subject, get close enough so that the subject occupies 1/3 to 1/2 of the space in your frame lines. This will create images with visual impact. 3: Watch your frame lines. Don't cut off parts of your subject's hands, feet, ears, head, etc. 4: Cropping off parts of the body works if you do it at the 1/4, 1/2 or 3/4 lines of the body (knees, waist, chest). 5: Experiment with both shallow depth of field and hyperfocal depth of field. See which you like best. 6: Experiment with slow shutter speeds - subjects blurred by their own movement can be interesting. Try bracing against a solid object and hand holding your camera with no support. See which result appeals to you. 7: Don't neglect doing some street shooting at night, especially at fairs, carnivals and festivals. Link to post Share on other sites More sharing options...
Advertisement Posted March 4, 2012 Posted March 4, 2012 Hi magosak, Take a look here Advice on 'street photography' . I'm sure you'll find what you were looking for!
BlackDE Posted March 4, 2012 Author Share #22 Posted March 4, 2012 Where to begin ? First, see how high the bar is. Have some idea of the work of the following: Andre Kertesz, Cartier-Bresson, Robert Klein,Helen Levitt, Tony Ray-Jones, Robert Frank, Gary Winogrand, Lee Friedlander, and look at the street work of Walker Evans (Many are Called). There are many more but that is a start. Winogrand rejected the term street photography. Most street photographs are dumb and fall into easy genres. I think most good photography has a larger ideas incorporated in it. There are all kinds of techniques but the main thing is to have conviction about what you are doing. I photographed in the street when I was young and was painfully shy and got nothing . I worked for years with cameras on a tripod, with no people. Recently I have been re-inventing myself as a street photographer, thanks to the M9. I am working in a single public space -- Toronto's provincial version of Times Square, and I think, after a year and a couple of thousand images, that I am starting to get something. Geoffrey James - Governor General's Awards in Visual and Media Arts Thanks a million! Bernhard Link to post Share on other sites More sharing options...
BlackDE Posted March 4, 2012 Author Share #23 Posted March 4, 2012 I would suggest the following - 1: Use a 28mm or a 35mm lens for your street photography. If you don't have either, shop around for a nice used 28mm f/2.8 elmarit. They can be bought for around $950US. A more economical but not wide angle alternative would be the 50mm f/2.8 elmar which can be had for $500-600US. 2: Get CLOSE to your subjects. If you are photographing a single subject, get close enough so that the subject occupies 1/3 to 1/2 of the space in your frame lines. This will create images with visual impact. 3: Watch your frame lines. Don't cut off parts of your subject's hands, feet, ears, head, etc. 4: Cropping off parts of the body works if you do it at the 1/4, 1/2 or 3/4 lines of the body (knees, waist, chest). 5: Experiment with both shallow depth of field and hyperfocal depth of field. See which you like best. 6: Experiment with slow shutter speeds - subjects blurred by their own movement can be interesting. Try bracing against a solid object and hand holding your camera with no support. See which result appeals to you. 7: Don't neglect doing some street shooting at night, especially at fairs, carnivals and festivals. Thank you, too, for your advice!! Bernhard Link to post Share on other sites More sharing options...
johnloumiles Posted March 4, 2012 Share #24 Posted March 4, 2012 Another technique that I use mostly (which some frown on) is shooting from the hip. It really entails shooting from the stomach. I have my strap set short and pull it down on my neck using two hands to ensure it's level then I zone focus and shoot. This helps especially when your in a crowed area and gives you a different perspective then coming from your eye down. Use a wider lens to limit the amount of throwaway shots you have, which most will be at first. Once you've done it for a while it becomes second nature and you can visualize the shot without looking. It's like using a medium format camera without the viewfinder. Link to post Share on other sites More sharing options...
