Leica S1 Questions
box86rowh
I recently came across and purchased a Leica S1 and I have some questions. First off, how do you tell the difference between the Pro, High Speed, and the Alpha? Also, I only got the body and need to find the cable, PCI card, and software. Any suggestions on how to find these?
Thanks!
Chris
Chris welcome!
I would ask the vendor in the first instance. The vendor should have possessed the instruction manual. If you bought from a dealer, he/she should be able to answer your questions. But the S1 is a very old digital camera, so finding accessories might be a problem unless you are lucky. Maybe a forum member with knowledge of this camera can help you. You could also ask customer services in Solms. I doubt they receive many questions on that pioneering model.
I called Leica in the US at least and they have a cable they are sending me but thats it. I also bought this at an estate auction, so no help there. It did come with the manual though. The only things it came with is 2 copies of the manual, a filter, and the HA 15350 Tilt-Shift adapter.
The 'camera' is really a scanner, and not a camera as such - because each exposure takes many seconds - so it's only suitable for still life/static subject matter.
Your manual should give you an indication as to which S1 model you have and it's likely you will need more than just a cable to enable your camera to be fully operational. The Hasselblad? tilt shift adaptor would have been an optional extra.
The complete S1 High Speed package comprised:
Leica S1 High Speed scanning camera body ( Mine was S/N 22862XX)
Leica M mount adaptor
Leica R mount adaptor
Interface box ( an enormous box of electronics several times bigger than the camera ... but the previous S1 models may not have required this box)
Power supply
Cable, camera to interface box
Interconnect cable, power supply to interface box
PCI board (SCSI board)
PCI interconnect
Mains cable with two pin plug
Siverfast Job Management Manuals (English and German)
Silverfast manuals (English and German)
Instruction manual in loose leaf binder
2 sealed Silverfast 4.X discs (CD) for Windows 95/98/NT or Mac OS ab V.7 … one labelled Leica S1 SF v4.2.0 and the other Leica / HDR+JM , Leica / HDR
Two floppy discs one labelled S1 HDR scan, the other labelled Leica S1 calibration
The whole outfit was in a dedicated storage box measuring 59cm x 63cm x 42cm … and total weight was 24 Kilos.
This link provides interesting information regarding the S1 http://www.l-camera-forum.com/leica-forum/digital-forum/13077-leica-s1-digital-camera-1997-a.html
Silverfast (Lasersoft GmbH) still offer software and software support for the S1 with Windows XP and Windows 2000 ie … SilverFast for Leica S1 High Speed :: LaserSoft Imaging
And this link provides additional information information about Silverfast’s S1 Scanning Software differenc between lasersoft silverfast ai & silverfast DCVLT : About SilverFast
I had an S1 High Speed but sold it because it was not compatible with my iMac or my PC ... the S1 requires a computer with an SCSI interface.
Your best bet for acquiring the additional items for your camera is to try and source a complete outfit with non-operational camera but the total production for all types of S1 was TTBOMK less than 200 . However, I have seen at least three offered on Ebay over the last three years.
Searching previous Leica Forum posts and threads revealed the following so you might find some further leads /members who can assist if you do further searches:
http://www.l-camera-forum.com/leica-forum/digital-post-processing-forum/185229-leica-s1-missing-driver.html
http://www.photoscala.de/Artikel/Tolle-Geschichte-Leica-S1
http://www.l-camera-forum.com/leica-forum/aktuelle-ebay-angebote/201913-ebay-de-leica-s1-pro-scanner.html
http://www.l-camera-forum.com/leica-forum/digitalforum/172666-s1-angeboten.html
http://www.l-camera-forum.com/leica-forum/leica-sammler-historica/172317-leica-s1-tilt-shift.html
http://www.l-camera-forum.com/leica-forum/ebay-offers/153410-honor-s1-leica-copy-50mm-f2.html
http://www.l-camera-forum.com/leica-forum/ebay-offers/144232-rare-leica-s1-pro-digital-camera.html
http://www.l-camera-forum.com/leica-forum/ebay-offers/139036-rare-leica-s1-pro-digital-camera.html
http://www.l-camera-forum.com/leica-forum/digital-forum/127790-new-toy-leica-s1.html
http://www.l-camera-forum.com/leica-forum/digitalforum/99015-leica-s1-alpha.html
Google is worth a look too eg The S1, The first digital Leica 1998 - Photo.net Leica and Rangefinders Forum
Good luck
dunk
