nickywaldo Posted September 11, 2011 Share #1 Posted September 11, 2011 Advertisement (gone after registration) Does anyone have a wireless tether solution for the S2? The LIMA cable connector is great, until someone stands on it and you tip to the floor with your camera in front of you..... Just got it back after 6 weeks of repair in Germany. Luckily I had the P version, so I got a loaner to use in the meantime.... Somehow, I would rather the cable fall out and lose that image than drop the camera... Anyway, wireless would be great if there is a solution and it is fast enough.... Many thanks! Link to post Share on other sites More sharing options...
Advertisement Posted September 11, 2011 Posted September 11, 2011 Hi nickywaldo, Take a look here S2 wireless tether . I'm sure you'll find what you were looking for!
dfarkas Posted September 12, 2011 Share #2 Posted September 12, 2011 Does anyone have a wireless tether solution for the S2?The LIMA cable connector is great, until someone stands on it and you tip to the floor with your camera in front of you..... Just got it back after 6 weeks of repair in Germany. Luckily I had the P version, so I got a loaner to use in the meantime.... Somehow, I would rather the cable fall out and lose that image than drop the camera... Anyway, wireless would be great if there is a solution and it is fast enough.... Many thanks! Nick, We've tried to use an Eye-Fi X2 wifi SD card with the S2.DNG files took an eternity to transfer even just 10 ft to our computer. Capturing DNG to the CF card in the camera and using the Eye-Fi card to send basic JPGs worked a little better, but still not what I would call speedy. You are correct. The LEMO connector will not give way if tugged. We tend to use active USB extension cables when tethering to create more slack and increase working range from the computer. This might help in the future. Some photographers prefer to shoot a few tethered tests, then unplug and shoot to CF card for the remainder of the session as they feel it is faster and everyone isn't hovering around the computer monitor. If you need a specific solution, Josh and I are happy to help. David Link to post Share on other sites More sharing options...
mwilliamsphotography Posted September 13, 2011 Share #3 Posted September 13, 2011 Stepping on the tether cord is not common, but it does happen. I have a hand strap on my S2, so it is less likely to be jerked out of my hand. Less likely, but not impossible. While Leica did solve the common issue of the tether cord falling out of the camera port, the locked proprietary camera connection also created the potential of snagging or stepping on the cord and having the camera and lens take a dive onto the floor. Being proprietary also made it hard to use easy solutions already on the market for standard USB/Fire Wire 400/800 tether connections. For example: I use a Jerk Stopper Tether kit from Tether Table Aero laptop podium tray mounts on all tripods including Gitzo and Manfrotto as well as any studio photography light stand with my Hasselblad H4D/60 to keep the FW 800 tether cord from falling out of the camera port in the middle of a shoot. Since there are short FW 800 extensions (12" or 36"), I also use one of those from the camera to the longer FW 800 tether ... that way it disconnects at that point if the cord gets snagged or stepped on while I'm moving around on the set or location. One could do the same thing with the S2 if there was a shorter tether cord version of the current one. If anyone could make one by shortening the current one it would be Paramount Sync Cords for Professional Digital and Flash Photography ... who has made shorter off-camera TTL flash cords for Nikon for years. Might be worth looking into if you do a lot of tethered work while moving around the set. -Marc Link to post Share on other sites More sharing options...
