Suggestions for f/0.95 Noctilux ND Filter
Noctilux4me
The new NOCTILUX allows for E60-filters, but it seems, you have to
get a special filter-adaptor for it. B+W has nd-filters in it´s portofolio, they
should have a type which will fit your needs..
Ask your dealer, he should know for sure.
On the other hand: go for VERY low ISO filmwise or on your digital M,
should give enough opportunites for splendid photographs.
best
GEORG
Which one specifically?
The B+W 60 103 ND0.9. But this is a three stop filter and you said you wanted a 6... although I'm not sure why you would need such a dark ND filter for the Noct .95. Personally I find 3 stops is more than enough.
I use the 3 stop and it works brilliantly. It works in all but the brightest of situations.
The B W one is highly recommended.
Please, you can have a link to buy it?
Thanks
Danilo
Sometimes in sunlight I find a 3 stop 8x filter to be insufficient even with the ISO reduced to 80 which unfortunately gives a reduction in dynamic range. (Ooops I've just noticed you don't say if you're using digital M8/9 or film.)
There are a couple of things to be aware of when using high value ND filters.
1. Filters with more than a 3 stop reduction are rarely color neutral. I have a B+W 64x which gives a distinctly brownish cast to the image. I have to do a custom white balance. The B+W 8x filter seems to be OK in this respect.
2. The filter glass has a finite thickness which causes additional attenuation for oblique light rays ie. corners and edges. This has the appearance of quite severe vignetting. It's very noticeable with the 64x filter and 0.95 Nocti.
As an example: If the glass thickness for oblique rays is 10% more than for (normal) central rays then an additional attenuation of 10% of 64x is much more noticeable than 10% of 8x. Not expressed very well but I hope you see what I mean.
I'm going to have to look into using Cornerfix to solve this problem.
Bob.
I am looking for a high quality, 6 stop ND filter for my Noctilux and was wondering is someone can recommend one... I am unsure about the ring size so not clear which one is appropriate.
Thank you in advance.
I purchased a variable density filter and an adapter ( the filter was slightly different sized) and am satisfied with the performance, as it allow for very different light situations in which I can use the 0.95 at full aperture.
If anyone is interested I would be pleased to give details.
Teddy
That would be great... Thanks in advance
The 0.95 Noctilux is E 60.
The variable density filter is named " I.C.W. 62 Os Fader-ND MK II (w-1)
The adapter is a B7W (3e) 62EI-60EA
I recall that the set was expensive, but I don't know exactly how much it cost, as it was a gift last Christmas from my daughter.
She bought the combination after long consultation with one of my favourite Leica dealers. I have not seen this filter in any shop in Cologne.
Hope this helps,
Teddy
