scrubs Posted July 31, 2011 Share #1 Posted July 31, 2011 Advertisement (gone after registration) M9 Problem Reporting Template. In an effort to collate information regarding the M9's lock ups and memory related problems Can anyone who has experienced any problems, please copy and paste the following text body into your post and highlight the relevant text corresponding to the setting on your camera used at the time of your problem in 'blue text'. This may serve as a useful resource for the technicians and possibly help resolve some issues . Could I also ask that this thread be used for this sole purpose only - So the thread does notget cluttered with comments and arguments! if you have any questions just PM k-hawinkler :D ISO Auto PULL 80 ISO 160 ISO 200 ISO 250 ISO 320 ISO 400 ISO 500 ISO 640 ISO 800 ISO 1000 ISO 1250 ISO 1600 ISO 2000 ISO 2500 Lens detection Off Auto Manual 16-18-21 ASPH F/4 @16mm 11626 16-18-21 ASPH F/4 @18mm 11626 16-18-21 ASPH F/4 @21mm 11626 21 f/2.8 11134 21 f2.8 ASPH 11135/11897 24 f2.8 ASPH 11878/11898 28 F/2 ASPH 11604 28 F/2.8 11804 28 F/2.8 11809 28 F2.8 ASPH 11606 28-35-50 ASPH F/4 @28mm 11625 28-35-50 ASPH F/4 @35mm 11625 28-35-50 ASPH F/4 @50mm 11625 35 F/1.4 11869/11870/11860 35 F/1.4 11874/11883 35 F/2 11310/11311 35 F/2 ASPH 11879/11882 50 F/1 11821/11822 50 F/1.2 11820 50 F/1.4 11868/11856/11114 50 F/1.4 ASPH 11891/11892 50 F/2 11817 50 F/2 11817 50 F/2 11819/11825/11816 50 F/2.8 11831/11823/11824 75 F/1.4 11814/11815/11810 75 F/2 ASPH 11884/11885 90 F/2.8 11800 90 F/2.8 11807/11808 90 F/4 11633/11634 MACRO-ADAPTER-M F. 90 F/4 14409 135 F/2.8 11829 135 F/3.4 APO 11889 135 F/4 11851/11861 Advance Standard Soft Discreet Discr. & Soft Self Timer Off 2s 12s Auto ISO Setup Slowest Speed Lens dependant 1/125s 1/60s 1/30s 1/15s 1/8s Max ISO Pull 80 ISO 160 ISO 200 ISO 250 ISO 320 ISO 400 ISO 500 ISO 640 ISO 800 ISO 1000 ISO 1250 ISO 1600 ISO 2000 ISO 2500 Sharpening Off Low Standard Medium High High Colour Saturation Low Medium Low Standard Medium High High Black & White Vintage B&W Contrast Low Medium Low Standard Medium High High Bracketing setup No. Of Exposures 3 5 7 Sequence 0/+/- -/0+ Ev Increments 0.5EV 1 EV 1.5 EV 2 EV Exposure Comp Setup SET menu only Setting ring Set. Ring & Rel. But. Monitor Brightness Low Medium Low Standard Medium High High Histogram Standard RGB Clipping Setup Off Over exposure only Over / Underexposure Auto review Duration Off 1s 3s 5s Permanent Rel. Button Pressed Histogram On Off Auto Power Off 1 min 2 min 5 min 10 min Off Flash Sync 1st Curtain 2nd Curtain Auto Slow Sync Lens Dependant Off (1/180s) down to 1/30s down to 1/8s down to 32s Color Management sRGB Adobe RGB DNG Setup Uncompressed Compressed Acoustic Signal Volume Off Low High Keyclick Off On SD card full Off On Language English German French Italian Spanish Japanese Trad. Chinese USB Connection Mass Storage PTP White Balance Daylight Flash Cloudy Shade Manual Kelvin Setting?> Compression DNG JPG Fine JPG Basic DNG & JPG Fine DNG & JPG Basic Resolution 1MP 2MP 4.5MP 10MP 18MP Exposure Comp. -3 -2 2/3 -2 1/3 -2 -1 2/3 -1 1/3 -1 -2/3 -1/3 0 +1/3 +2/3 +1 +1 1/3 +1 2/3 +2 +2 1/3 +2 2/3 +3 EXP Bracketing Off On Shooting Mode Single Continuous Timer Lens Used>? Firmware Version?> Ambient Temperature>? Battery Level>? Memory Card Model>? Symptom Description & Additional Comments . Link to post Share on other sites More sharing options...
Advertisement Posted July 31, 2011 Posted July 31, 2011 Hi scrubs, Take a look here M9 Problem Reporting Template . I'm sure you'll find what you were looking for!
jamesk8752 Posted July 31, 2011 Share #2 Posted July 31, 2011 Nice work! I'll be interested to read posts using this. Hope the mods will make this a sticky... Regards, Jim Link to post Share on other sites More sharing options...
k-hawinkler Posted July 31, 2011 Share #3 Posted July 31, 2011 Please see my comment here. http://www.l-camera-forum.com/leica-forum/1787166-post80.html Please, don't start reporting just yet. This needs to be iterated with Leica by the admin Andreas in order not to waste any effort. We need a systematic effort, developed with consensus between Andreas of the forum and Leica. Please, hold your horses until then. I expect that to happen shortly. The call for participation should come and will (I believe) from the admin Andreas. Please, let's not rush this. Give it a day or two. This is a unique opportunity. We don't want to blow this. Thanks, K-H. Link to post Share on other sites More sharing options...
andybarton Posted July 31, 2011 Share #4 Posted July 31, 2011 Andreas will make an announcement with the relevant details. Link to post Share on other sites More sharing options...
