M6/7 shutter speed query by leica newbie
andyedward
I`ve noticed that the maximum shutter speed for the M6/7 is 1/1000, but with an f1,4 lens, wont images be overexposed in very bright conditions?
I ask because sometimes I shoot at faster shutter speeds than 1/1000 at f2.8 on a dslr, but the digital look no longer does anything for me, and the lure of an M6 or 7 with M lenses calls to me!
It depends upon which film you are using.
If you are using slow film (you can go down to 25 ISO or less, if you wish) and you are still getting over exposure, you will need to use an ND filter.
You don't HAVE to use f1.4 all the time, btw ;)
This is an issue in Australia - and one thing in favour of the Zeiss Ikon with its 1/2000 speed.
Whatever your preferred parameters, you will still find there are limits. As I shoot a lot of low light stuff I find the limit for me is at the other end. ;)
Film Leicas (most) do have their shutter speed limit at 1/1000th. I shoot a Noctilux, mostly at f1.0, and that can be an issue for overexposure in bright situations. I have a ND filter for just that cure. The Zeiss 1/2000th would also be insufficient. But whatever the upper limit for shutter speed on any camera, there will be an occasion when you want more. Simply work around it.
...no slow film available for purchase in/from Australia, then, Alex?
