wstotler Posted February 9, 2007 Share #1  Posted February 9, 2007 Advertisement (gone after registration) This morning I slapped the 15mm Voightlander (4.5) lens that arrived yesterday up on my M8 and did a QTVR semi-spherical panorama shoot.  The advantage of the 15mm lens (19.5mm equiv on M8) is that I was able to get the pano in 18 shots instead of 30+.  The results were OK for a *very* quick-and-dirty test and the 15mm looks promising--even with its vignetting, 4.5 stop, and lack of fine detail when compared to one of the Leica Cron lenses.  I didn't spend much time adjusting the pano's nodal point, which accounts for some nasty ghosting in a few areas.  I also didn't do much in the way of color adjustment.  And I have a grease/dust blob or two. (Shame on me.)  In short, the pano work is pretty awful--but I wasn't trying. I was checking out the lens.  The point is that in a 30-minute test without much fuddling, this pano came out (in terms of resolution and detail) much, much better than the Digilux-2's panos. (Which is what I wanted to test.)  So, even with full-on operator suck and hurried, no-attention-to-detail work this pano still beats out the Digilux 2 when everything is "spot on." It can only get better.  Here it is: http://www.a23.com/M8/M8_Voightlander15mm_QuickQTVRPanoTest.mov  I recommend that if you want to view it (16M) you right-click-save-as and download it--then launch it in QuickTime on your computer instead of viewing it in your Web browser.  And. . . . Are other QTVR pano people using the M8?  Later! Will  P.S. You can zoom in and out with the SHIFT and OPTION keys. Link to post Share on other sites More sharing options...
