Tunning M8?
maccaco
That's quite a difficult question. Your good taste is probably different from any other member in this forum. To me for example, is leaving my M8 as is, to others is pink leather covering.
I suppose that the better thing is you do those changes by yourself according with your taste. I think on the forum you will find plenty of instructions to perform any kind of change.
Any specialist will be able to help. I'm not sure where you are, but Malcolm Taylor in the UK would be able to do this work for you. If you are not in the UK, I'm sure you'll be able to find a local specialist that can strip the M8, have the top and bottom plates repainted, and recover the body in whatever finish you want.
I will look if there is someone in Barcelona. Thanks for the info! :)
