Problem with 50 1.4 E43 aperture ring
tuanvo1982
It is a bad day to me. The aperture ring of my Leica 50mm 1.4 E43 type 2 doesn't work anymore.
Once I turn it around, the blade doesn't change. If I try to put it down or pull it up a bit and turn it around then it works but doesn't stop at every half stop. I think the problem with the small ball which is inside of the ring.
Even, if I try to screw or unscrew then it seems to be turned around forever.
The lens still has around 9 warranty months. It just got serviced at Jan of 2011. I don't want to send it to Germany :(.
Do you have any idea please?
Thanks
The aperture blades is a complex mechanism - I still think you should consider sending in to Leica. The E43 is not a new lens - things like this might happen and I only trust Leica when it comes to lens repairs.
