Steve33 Posted April 27, 2011 Share #1 Posted April 27, 2011 Advertisement (gone after registration) Hi, I am looking at buying a polarizer to shoot some slide films. I like the effects of a polarizer on blue sky. Sorry for my ignorance but should I buy a linear or circular filter? Since I can't see the results of the polarizer as for a SLR, should I go with a linear? Thanks. Steve Link to post Share on other sites More sharing options...
Advertisement Posted April 27, 2011 Posted April 27, 2011 Hi Steve33, Take a look here Polarizer for my M7. I'm sure you'll find what you were looking for!
tgray Posted April 27, 2011 Share #2 Posted April 27, 2011 Buy a linear one. A circular one is usually recommended for autofocus SLRs so the autofocus can operate properly. It can also affect the metering if I recall correctly. Since your M doesn't autofocus, it's not an issue. The metering won't be affected either due to the way M's meter. Link to post Share on other sites More sharing options...
budrichard Posted April 27, 2011 Share #3 Posted April 27, 2011 Leica makes a Polarizer that has a swings up to the rangefinder window that allows you see the effects and it fits a number but not all of their lenses. I have a couple and they work fine.-Dick Link to post Share on other sites More sharing options...
Guido Posted April 27, 2011 Share #4 Posted April 27, 2011 Personally, I just put on a standard non-Leica circ polarizer and rotate the filter while watching the exposure meter display to find the desired position. Link to post Share on other sites More sharing options...
lincoln_m Posted April 27, 2011 Share #5 Posted April 27, 2011 Steve, I bought this a few years ago. Kenko Rangefinder polarisers | Robert White Photographic Ltd But apart from dropping the exposure down by 2 stops I've never seen any difference on Velvia slide film. I get a better effect by underexposing a little say 0.5 stop while getting that 1.5 stop difference in shutter speed or DOF. My experience with filters on Leica lenses has been generally poor with a feeling that one is putting a cheap piece of glass in front of a very expensive and high quality lens. So now I don't even use a UV filter as they are able to catch light and cause flare. I do use the lens hoods though, they do work great. If you are local to UK perhaps we can do a deal for my E39 screw filter polariser if you like or even a loaner to try it out. As I said I don't think they are worth the -2 stops, but perhaps I have used it when the sun is high 10am - 4pm? Regards, Lincoln Link to post Share on other sites More sharing options...
Steve33 Posted April 28, 2011 Author Share #6 Posted April 28, 2011 Thanks to all for your replies. I think I will go with a linear polarizer as suggested. Never thought to look at the meter readings for a circular polarizer. Good idea. Link to post Share on other sites More sharing options...
tgray Posted April 28, 2011 Share #7 Posted April 28, 2011 Advertisement (gone after registration) Thanks to all for your replies. I think I will go with a linear polarizer as suggested. Never thought to look at the meter readings for a circular polarizer. Good idea. It will work for a linear polarizer too. On a camera that doesn't need a circular polarizer while metering that is. Link to post Share on other sites More sharing options...
Double Negative Posted June 21, 2011 Share #8 Posted June 21, 2011 Maybe this will help explain the options... Polarizers and the M System. I have the Leica Universal Polarizer myself; works rather well. Link to post Share on other sites More sharing options...
juergen Posted June 22, 2011 Share #9 Posted June 22, 2011 I have the Leica Universal Polarizer myself; works rather well. +1 Juergen Link to post Share on other sites More sharing options...
