Thumbs Up CSEP-2
paulpp
Have just taken the plunge and ordered one to improve the grip on the camera. Spent sometime considering the Leica grip, but cost is an issue so went with the Thumbs Up.
Am I going to be disappointed?
I got my CSEP-2 a week ago and i was excited about the improvement. It gives the cam a perfect grip, so you can shoot one-handed without fear of dropping your x1. I was surprised how such a little thing can make this difference.
Im also interested in a Thumbs up ...but are they not more expensive than the Leica Handgrip ?..... which i already use.
Also will they in time mark the X1 ... as i have seen an image of an M8or9 marked after using one.
Brian
The CSEP-2 is the only add-on I have on my X1. It greatly enhances handling, and renders the comparatively bulky Leica handgrip completely unnecessary.
There's no sign of it marking my (black) X1 so far. If the retaining screw is tightened to prevent movement of the TU relative to the camera, I doubt there will be any.
I have used the thumbs up since December
In short it increases the usability of the x1 I can now hold it comfortably just inches from my eye a more natural position for me to shoot with, I use It along with the wrist strap.
It is VERY IMPORTANT not to overtighten the hex nut in the hot shoe.
I have been using mine for 6 months, very handy but I just discovered that the upper plate of the X1 is getting a bit loose...
Probably not designed to whitstand the torque induced by the Thumbs-up in the vertical axis. I removed it since.
Did anybody encoutered similar issue?
Thx.
Thx.
Whoa- I guess that settles it for THIS THREAD everybody. As you can see, I had the same issue. First the TU gets a bit loose, so you tighten it, next thing you know the top plate is separating.
Interesting that I wasn't the only one. It can't be emphasized enough to NOT OVERTIGHTEN THE HEX.
My conclusion is that the TU may be OK for an M8 or M9 as their construction is much more robust, but certainly not for the X1. The top plate of the X1 is very thin and probably loosely fixed.
Too much stress is transfrerred by the TU in the vertical direction especially when the protrusion of the TU is abruptly sollicited (ex: in and out of pocket)
Bottom line: I don't recommend fixing a TU on the X1 when the camera is extensively used.
My 2 cents.
Well mine arrived today - very quick delivery. First impressions are that it is very well engineered and certainly improves handling. Will keep my fingers crossed (although not when handling the X1 !!)
I just wrap the strap around my wrist. I've done this with every camera I've ever owned...SLRs and Ms.
Given I had a camera in each hand, I hope the attached pic shows you what I mean.
i did that prior to purchasing the thumbsup and wrist strap----> there is a world of difference in handling between wrapping the neck strap and the thumbsup-- just my opinion-yours may be different
Just buy yourself aLuici halfcase and all your problems are solved...:)
  • 2 weeks later...
I've been a long term userbof Thumbs Up devices - M8, M9 and now my X1. Very happy with the M models but disappointed that the small spring steel plate intended to hold the viewfinder in place has come loose and rattles. I would not have expected that given the relatively high price of the device.
However, the camera top plate is still secure!
loosen the set screw!!! you have overtightened the TU
