Fang Posted April 20, 2011 Share #1 Posted April 20, 2011 Advertisement (gone after registration) I have been reading through the manuals looking for the multi-exposure feature in D-Lux5 but I am unable to find any. Can someone help with this ? and can someone guide me on how to use this feature ? Thank you in advance. Link to post Share on other sites More sharing options...
Advertisement Posted April 20, 2011 Posted April 20, 2011 Hi Fang, Take a look here D-Lux5 Multi-exposure feature . I'm sure you'll find what you were looking for!
jtori Posted April 20, 2011 Share #2 Posted April 20, 2011 Hi Fang, Make sure the camera is not in Auto mode. Press the Menu/Set key button and scroll down to Multi Expo. Hit the right arrow and press Menu/Set to initiate the process. Then, take a photo. Press the Menu/Set key to select Next. Take the next photo. Press the Menu/Set key to select Next and take the final photo. Finally, press Menu/Set to select Exit. When you hit play you will see your multiple exposure image. At any point along the way you may retake an image. Three images is the default. You may set the camera to take more if you wish. I've attached an image I made using the mult-exposure function. Hope this helps. Best of luck, Joe. Link to post Share on other sites More sharing options...
missmarvell Posted April 21, 2011 Share #3 Posted April 21, 2011 Thanks to you guys, I learnt something new Link to post Share on other sites More sharing options...
