My M6 seems to have jammed :(
SuperFish
After finishing a roll today I wound on to find the end of the film or the last frame. All of a sudden there was an odd click from where the take-up spool is inside the camera. I had trouble rewinding the film as it seemed jammed. Eventually I got the film out but I'm unable to wind my camera on without a film in. The lever just doesn't want to move?
Any help or advice is very much appreciated, I just don't want to be separated from my beautiful work horse.
Thanks,
Fish
remove lens cap, open the lens wide and set the ISO to 1000, what serial nnnxxxx willdo.
i) try setting the shutter to 'B', dont use force if it does not want to click round as it normally would. Sometimes the shutter will click when taken to B if it is in mid sequence, If it does you may have done something wrong or the camera may have been too cold for its lube.
ii) set the rewind lever to rewind and try and rotate the sprocket shaft in each direction, it should spin freely, if not there is something wrong.
Noel
