Huey Pro
calshot
Slowly getting used to my new iMac.But not sure about the Huey.Worked fine on the old PC but on the iMac I notice that the small icon, top right corner often has a white X showing.
what does this mean? Have I not installed correctly.
Any help would be most useful.
Rob
I also had this problem when I changed to an iMac even with the latest download from Pantone. The Huey seemed to profile the screen and produced a new profile which hardly varied fron the iMac's default setting. The Huey didn't adjust the screen with ambient light changes either. I was told that it's a 32 bit/64bit software compatibility problem.
I have now invested in a Datacolor Spyder 3 Elite upgraded to 4 software which automatically adjusts the iMac's screen brightness and contrast and performs a faultless calibration profile from the iMac's default screen profile. Using the correct profiles for the paper I am using I now get prints that near enough match the screen image.
If you or anyone else decides to use the Spyder 3 Elite, you should ensure that you purchase it with the upgrade to version 4 as this is the bit that gets into the iMac's brightness/contrast setting software to enable such a good calibration. Well worth the investment IMHO.
Well even more confused now.I downloaded what I assumed to be the correct app for my iMac.When I checked the version it came up 1.51.Isn't that a Windows version? So I have re-installed again from the download now I am getting a red square top right and the programme, when you run starts off brown not green.So does the iMac not support the Huey Pro?
Rob
Rob, I had to convert the sw version when my windoze machine died. I called the Huey guys and they found my purchase record and sent me a link to the correct sw version for my MBP.
They were really nice and the software works like a charm. The Pro version is required to calibrate a second monitor.
Thanks for all the help I may have sorted it.Instead of downloading I installed from the CD at purchase.This might mean I am an upgrade or so adrift but lets see.
PS Yep Green is HueyPro
Brown is Huey
I'll try for a while and see.
Rob
Brown is Huey
Rob
My Pro is also green, but my regular Huey is red.
Thanks Rich
Pretty much as I have discovered.No it's not much of a fix.I suppose the Huey is getting old now so I expect they would prefer we just went out and purchased an upgrade.
Rob
Rob, the upgrade is probably free. See what they say about your unit.
The Pro doesn't seem much different from the Regular except for calibrating a second screen.
