tyler Posted October 21, 2010 Share #1 Posted October 21, 2010 Advertisement (gone after registration) Is it possible to apply Corner Fix correction without leaving Lightroom--like I do when I choose EDIT IN and select PS or Nic adjustments from the pull down menu? Can I put the Corner Fix application in the Adobe application support folder where the Nic adjustments are located and select corner fix in Lightroom? OR--do I have to open the file in Corner FIx, apply the correction (my saved correction file) and then import into Lightroom. All this using a MAC thanks tv Link to post Share on other sites More sharing options...
Advertisement Posted October 21, 2010 Posted October 21, 2010 Hi tyler, Take a look here Corner fix and Lightroom. I'm sure you'll find what you were looking for!
sandymc Posted October 22, 2010 Share #2 Posted October 22, 2010 Is it possible to apply Corner Fix correction without leaving Lightroom--like I do when I choose EDIT IN and select PS or Nic adjustments from the pull down menu? Can I put the Corner Fix application in the Adobe application support folder where the Nic adjustments are located and select corner fix in Lightroom? OR--do I have to open the file in Corner FIx, apply the correction (my saved correction file) and then import into Lightroom. All this using a MAC thanks tv You can't use CornerFix from within Lightroom, I'm afraid - you have to open the file in CornerFix, do your corrections, then save the corrected file and open the corrected file in Lightroom. Sandy Link to post Share on other sites More sharing options...
hoppyman Posted October 22, 2010 Share #3 Posted October 22, 2010 Sandy, pardon my ignorance as I haven't used your Corner Fix. What formats are supported? Link to post Share on other sites More sharing options...
sandymc Posted October 22, 2010 Share #4 Posted October 22, 2010 Sandy, pardon my ignorance as I haven't used your Corner Fix.What formats are supported? Geoff, DNG files. As of version 1.4, pretty much any DNG file will work, including those converted from other raw formats, as well as those converted from TIFFs, written from DxO, or whatever. So it's possible to use CornerFix with Nikons, Canons, Sony Nex's etc, etc by converting with Adobe's free DNG Converter program. Regards, Sandy Link to post Share on other sites More sharing options...
hoppyman Posted October 22, 2010 Share #5 Posted October 22, 2010 Thanks Sandy. That is the perfect answer of course Link to post Share on other sites More sharing options...
