Reconstructing deconstructed cable release ... Solms? Anyone?
Constable
I don't know if anyone has had any experience with the S2 cable release. My example just decided to deconstruct itself in my camera bag (I probably partially unsrewed at some point I suppose). I think I have all the bits .... but does anyone know the correct assembly sequence?
The critical questions relate to parts A and B ... which way round do they go? How doe you ensure the pins are correctly lined up? And weher does the spring go?
before using the good old trial and error approach, I though I'd see if anyone had first hand experience of the interior of this releae.
Thanks in advance
Ed
Thanks Pete,
Actually the problem is more with the RRS L-bracket - it makes access to the socket a bit toght and a tendency to twist! That was probably the problem.
All solved by the application of money and a replacement cable ... which I might just partially "deconstruct" to see how it all goes together!
Ed
