noctilux retractable lens hood removal?
leicaM8freak
Hi all, using the Noct (latest model), it is a bit of a pain the way the finder is blocked by the lens hood.
I understand that some people removed the retractable hood altogether.
That is what I am planning to do also
Any advise on how to do this is welcome.
And please, please no comments on "loss of value" and "buy a old model with removable hood", I have read those already
Thanks
Remove the three screws at 120 degree intervals just in front of the aperture ring and the filter holder pulls off. You need a screwdriver of the correct size and, depending on how picky you are, you'll want to protect the front edge of the aperture ring with tape while you are using the screwdriver to prevent it marring the finish, also some black enamel to touch up the screw heads.
I think you'll find the grub screws are pointed and make indentations into the softer lens barrel, so when you refit the holder without lens hood, you'll want to make sure the screws re-engage in the same indentations - it will help to mark the position of one of the screws with a soft pencil.
  • 8 months later...
Mark, thank you very much for the speedy, crisp and clear answer.
I will try to do this later this evening, but I trust it will work perfectly!
Thanks again
Piet,
Did you ever get around to doing this, and if so how did it go?
Regards
Eric
