Sharper with or without ir/cut filter
Guest willjanurgucken2000
Good Morning!
In the last days I was reading some posting about the M8 and sharpness with or without filter.
The hypothesis that the M8 is sharper with an ir cut filter was repeated more often.
Is that right? Personally I can not find any difference if I work with or without filter...
If yes, whats the technical cause for that.
best regards
will
Good Morning!
best regards
will
The technical explanation is that IR light focuses in a slightly different plane to visible light - and so you would get some blurring due to defocused IR light. I noticed that B&W output without IR filter seemed to have less resolution of fine detail - but I never tested it 'scientifically' ;)
