is the battery or the charger?
super7668
x
After a long stint in the charger, what does the charge indicator show on your camera?
I don't have time to use the M8 heavily these two days; however I can't find anything about the flashing green light in the M8 menu. What does it mean?
Usually a fault condition signalled by a charger indicates that the battery is bad or the battery has over heated during the charging cycle. If you can find another M8 user or a photo shop with a M8 charger, see if the same fault occurs with a different charger. You probably need a new battery.
pattern batteries sometimes give problems, the chip in the cell fails to communicate with the charger, I've had 2 fail, but at 9x cheaper than a Leica I'm till well ahead. The genuine battery list price is plain silly, and even they go wrong sometimes.
  • 3 weeks later...
I just had another battery go out of the blue, pattern cells seem to last well enough, but the charge indicator bar doesn't register charge condition (looks fully charged all the time) - the battery then just fails unexpectedly...
