SF20 off-camera connection to M8
wda
There are several threads dealing with using the obsolescent SF20 flash unit fixed to the M8, but I cannot find any which deal with the use of the same combination 'off-camera'.
My SF20 has lain unused since my M6 film days and it seems a pity not to explore its usefulness tethered 'off-camera'. Although I rarely use flash with my digital cameras I do enjoy the occasional use of the tilt flash on my Digilux 2. In the absence of a similar facility for the M8/M9 cameras, and accepting that many members prefer the later SF24D or third-party solutions, I would be happy to accept the minor limitations of the SF20 provided I can use it 'off-camera'.
I have read that a specific Nikon lead works with the later flashes. Has any member had a successful experience linking the M8 with the SF20 'off-camera'? Any details would be welcome. Thank you.
x
Nicole, thank you. Yes, I realize the loss of TTL/GNC, but am prepared to accept that initially while I evaluate its usefulness. My plan is to use the flash in bounce mode from any nearby light surface or improvised flash attachment. If then TTL looks like a useful facility, I will upgrade, but initially I would like to test the feasibility, using the histogram as a guide to exposure. Has any member actually used my proposed combination?
Can I assume that the suggested leads would work equally well with the SF24D?
Hi David,
I haven't tried this combination myself, so I can't help much as far as advice goes on that. But the Nikon cables will work with Leica M/R/X cameras and SF20/24/58 flashes. All that these cables do is give you a direct pin-to-pin connection. Nikon and Leica pins just happen to be in the same places. :)
If you're bouncing the flash you won't be able to point the sensor of the SF20 at the subject, so you'll have to set the flash to manual rather than auto ... in which case you don't need a cable that provides data communication between camera and flashgun and can use a plain old hot-foot to hot-shoe extension cord, which should be cheaper than the Nikon ones.
what pins does the auto (thyristor) mode need?
Auto mode only needs the basic trigger circuit, so none of the additional pins are needed for that. But you still need to point the sensor in the flashgun at the subject for auto to work properly. If you are bouncing the flash you'll need to calculate your aperture manually.
.... or use a Flash Meter .... or guess and check the histogram ...
...I still haven't seen a good bounce flash solution. I think the SF58 is too ungainly in portrait orientation, and a cord is not enough because I need both hands to operate the camera. I use the SF24 and carry a Metz 36Cl-2 for bouncing, which I put on a bracket. (Flash has no swivel.) I have the Nikon cord, but I also use two adapters, one with a short 6" cord. You might also try a diffuser ("Sfill," etc.) in lieu of bouncing.
