Changing lens info in EXIF
eritho
RoySmith...
Now that MobileMe is no longer available, can you send me your tool in any other way?
Thank you!
Maurizio
Hi
Since MobileMe's demise I started using dropbox.
I put a copy of the SetLeicaExif.app here. With this script you can drop a single file, multiple files, or folders of files on the script and the image files will all be set to the same lens information.
Also here is another script which uses ExifTool for viewing all the Leica DNG EXIF info.
Both of these scripts require that ExifTool by Phil Harvey is installed. It is wonderful that Phil Harvey has gone to the work of creating and maintaining this utility.
Ciao,
Roy
