barnack Posted August 4, 2010 Share #1 Â Posted August 4, 2010 Advertisement (gone after registration) I just acquired a Leica R8, but what appears to obvious is not. Can any explain how to remove the housing to replace the batteries in the R8. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted August 4, 2010 Posted August 4, 2010 Hi barnack, Take a look here Leica R8 Battery Removal. I'm sure you'll find what you were looking for!
andybarton Posted August 4, 2010 Share #2 Â Posted August 4, 2010 There's a button on the hand grip that you push in, then slide the grip part down off the rest of the body. Link to post Share on other sites More sharing options...
stunsworth Posted August 4, 2010 Share #3 Â Posted August 4, 2010 The button is a silver metal slider on the bottom of the camera. Slide it and the handgrip should slide off. Note that the grip can sometimes be rather stiff. Link to post Share on other sites More sharing options...
rubenkok Posted August 4, 2010 Share #4 Â Posted August 4, 2010 Hi barnack, Hope this is some help Kind regards, Ruben Link to post Share on other sites More sharing options...
barnack Posted August 4, 2010 Author Share #5 Â Posted August 4, 2010 Thanks for everyones help. You were all right, it is rather stiff to remove. Link to post Share on other sites More sharing options...
andybarton Posted August 17, 2017 Share #6 Â Posted August 17, 2017 Try squirting some WD40 onto a cloth, then rubbing on the plastic parts that are binding Link to post Share on other sites More sharing options...
stunsworth Posted August 17, 2017 Share #7 Â Posted August 17, 2017 Advertisement (gone after registration) It's a great camera though and I'm sure that I can live with this annoyance but it would be nice to be able to remove the cover without any problem! Â Â It's the best SLR body I've ever used - I preferred it to the SL that I also once had. Ergonomically it's superb, it may look bulky but everything falls into place. Link to post Share on other sites More sharing options...
masjah Posted August 17, 2017 Share #8 Â Posted August 17, 2017 R8s and R9s (including my own) are sometimes susceptible to this - I've never understood why, though it's more of a nuisance than anything else. Here's my technique, FWIW. Remove lens and fit body dust cap. Hold the camera with both hands, against your chest, base away from you, top against your chest, front uppermost. Hold the catch open with your right index finger, carefully insert your left thumbnail between the battery cover and the bottom of the chrome decorative strip, and push down. This usually gets it started, then it's fine. Personally I wouldn't use a knife blade, as the chrome strip is easily damaged. Link to post Share on other sites More sharing options...
