Can I use my 50mm F1.4 lens for landscape?
mark744
To the OP, where are you going? Can you practice near your place? 50 is great for landscapes. The framelines require careful composition, not a bad thing at all. Here's one with the 50 'cron.
  • Replies 42
  • Created
  • Last Reply
I used to do some yearly backpacking up north, above the Arctic Circle. Lots of wide expanses -- somewhat like the Scottish Highlands with reindeer instead of sheep, and permanent snow on the mountaintops.
During several trips, I carried just one camera with a standard lens. Later, I used a Olympus OM SLR with a standard (50mm) lens, a lightweight 135 and occasionally a 24mm. I found that the 50mm lens accounted for over ninety percent of all the shots. During my last expeditions I carried a Leica M6TTL with 50 and 90mm lenses, or even a Rollei 35 with its fixed 40mm lens.
Conclusion: The 50mm focal length is the best length there is for landscapes! Even though I am very much a 35mm man.
The old man from the Age of the Wide Open Trails
I'm going to New York, but I travel all the time as part of my job. With my other gadgets and the fact I only ever take a carry-on bag I need to travel as light as possible, despite the limitations.
Thanks for all the comments...
