Light leakage between frames?
DerekF
I recently took these shots with my MP. As you can see, the sun was at the extreme edge of one of the photos and leaked into the next frame. I've had this happen before, although not as badly as this one did. Aside from this, I've not experienced any other problems. Is this normal or should I consider sending it to Leica for a once-over?
Guest nephilim
I got a similar result a few months ago. I took a photo with the sun close to the upper border and as you can see in the (cropped) scan below, it's clearly visible in the following frame. Film used was TMax400 in an M7 w/50/1.4 ASPH. The guys at rangefinder forum told me it's light-piping and no camera problem. I haven't seen any issues in 'normally' lit circumstances. However, the whole kit went to Leica recently and they also replaced the light seals. But this might be connected with the replacement of the DX reader...
I think this is light creeping through the film itself.
In both cases there is an (enormous overexposed) image of the sun in one frame. This could cause that the carrier substrate is working like an optical fiber and the light is creeping through the carrier film into the next frame. To prevent this there is an anti halo coating on the backside of the film, but with such heavy lights it might have failed to absorb all of it.
...this is great stuff, Steffen - I never considered the carrier substrate in all my research into the matter. I have a vested interest, primarily because I shoot a lot of low-light, and I sometimes have to shoot "into the light".
DerekF and Torsten, re: light seepage, I recommend reading through this entire thread - in particular, posts #13 & #19.
I found it very informative and I think it is relevant to this discourse.
Same lens, a 35 Summilux-ASPH. Unfortunately, I don't know what aperture it was shot at. I believe the shots were taken a few seconds apart.
...all my occurrences of this phenomenon have been restricted to lenses below the 40mm focal length. My unscientific conclusion is that it is related to the positioning of a very strong light source on or very near the edge of the frame of an image captured (invariably) with a wide-angle lens.
I do not think that this has much to do with the focal length of used lens. It´s just more often the case that the sun itself is part of the image when it is taken with an wide angle than it is with a tele lens.
...Steffen, you may be right about the relevant focal lengths (post #12). I just checked out some negatives shot with the Voigtlander 50mm f1.1 some time back - yup, you guessed it, there is ample evidence of light creeping under the film gate. Not excessively, but it is there.
...having reviewed your images again, DerekF, I would say the second frame exhibits both leakage and flare.
Yeah, I know about the flare. They're not the best images in the world. :o I was more concerned with the obvious light leak between frames. Based on the discussion here, I'll be more careful with strong light sources near the edge of the frame!
Guest dk_samurai
I think this is pretty normal and I have seen this with many cameras.
+1
Just be aware that if you capture a strong light source near the edges of the frame, it will creep a bit into the next frame. Nothing wrong with your camera.
This will also happen if you shoot a frame that is completely overexposed: here again some of the light will creep into the next frame. Just be aware of that when loading film, for example.
/David
