Paolo.Battista Posted June 21, 2010 Share #1 Posted June 21, 2010 Advertisement (gone after registration) Does anyone know if it's possible to mount the Elmarit-R 19 f:2.8 (second version, with built in filters) on the Digilux 3 body? Formally, the Leica R adapter for 4/3 mount supports only lenses down to 30 mm. In case, can you suggest me which adapter do I need? I tried my actual adapters (from Coma), but they doesn't fit in the 19 f:2.8 mount. I use them on many R lenses, (specifically: (Cron: 35 and 50), (Elmarit: 35, 100 APO macro, 135), (Telyt:180 APO 3.4, 250/4 280/2.8 APO), (Lux: 80)), and they're working fine with all of them. My best regards. Paolo Link to post Share on other sites More sharing options...
Advertisement Posted June 21, 2010 Posted June 21, 2010 Hi Paolo.Battista, Take a look here Elmarit-R 19 f:2.8 on Digilux 3 . I'm sure you'll find what you were looking for!
TonyMCS Posted June 21, 2010 Share #2 Posted June 21, 2010 Hi Paolo I use a Novoflex R to 4/3 adapter on Digilux 3. The Elmarit-R 1:2.8/19mm version 2 fits OK. The distance scale is a bit off, this could be the lens (bought used) or possibly the adapter thickness made to the bottom tolerance limit deliberately to ensure infinity focus. I get infinity focus a few mm to the left of the infinity mark. A bit of recalibration with tripod, tape measure and a thin strip of masking tape on the lens marked off at the correct positions works - if you need an accurate scale. Elmarit-R 1:2.8/28mm is OK too. The Novoflex is not the cheapest (but less than the Leica or Panasonic adapters) but the fit and finish are excellent. I also have an adapter from the Far East, not as nice a finish or fit but it works OK. Not sure why your "Coma" adaptor doesn't fit. Tony Link to post Share on other sites More sharing options...
Paolo.Battista Posted June 22, 2010 Author Share #3 Posted June 22, 2010 Thanks Tony. The problem with the Coma's adapters is only a mechanical one. The bayonet does not allow to mount the Elmarit 19 since one of the flanges (on the Elmarit)is too long and doesn't fit in the adapter mount. I suspect that the Coma adapter is a strict copy of the Leica one. Infact, the original adapter from Leica is specified to work with lenses starting from 30 mm up to 1600 mm. I will buy the Novoflex immediately. My best regards. Paolo Link to post Share on other sites More sharing options...
