novice9 Posted May 30, 2010 Share #1 Posted May 30, 2010 Advertisement (gone after registration) can someone please explain how to compare these following reproduction ratio stats to one another. leica 75 2.0 "1:7" nikon zoom lens "0.15x" so, is the nikon lens equate to 1:15 in leica terms, which means its maximum reproduction ratio is less than the leica lens, or is is rather 1/15, in which case the nikon lens would i believe be slightly better? thanks much. Link to post Share on other sites More sharing options...
Advertisement Posted May 30, 2010 Posted May 30, 2010 Hi novice9, Take a look here Reproduction Ratio. I'm sure you'll find what you were looking for!
Guest trond Posted May 30, 2010 Share #2 Posted May 30, 2010 Dear Novice9, A reproduction ratio of 1:7 is the same as 0.1428X, or slightly less than 0.15X, which is 1:6.67 the other way around. In other words the nikon zoom will give a 5% higher reproduction ratio than the 75 cron. Probably not that visible in the images. Best regards Trond Link to post Share on other sites More sharing options...
adan Posted May 30, 2010 Share #3 Posted May 30, 2010 Take 1:7 and divide the 7 into 100 - I.E. Leica 75 repro ratio is 0.143x Alternatively, divide 100 by 15 (or 1.0 by 0.15 - same thing) to get 1:6.7 So yes, that particular Nikon zoom frames 5% tighter ___________ amazing how great minds think alike..... Link to post Share on other sites More sharing options...
novice9 Posted May 30, 2010 Author Share #4 Posted May 30, 2010 thanks so much, that's very helpful. as a follow on question, is there any easy way to compare the reproduction ratios of the 75 and 90 crons at given distances from the subject? ie, i realize the 75 has a higher max reproduction ratio (7 vs. 9, though you'd have to stand so close to the subject you would be a distance that the 90 could not focus, if i understand correctly), but at any given distance from the subject that may not be the case. is there a cross over point, or does the 90 cron always yield a better reproduction ratio at the minimal distance that 90 can focus at? thanks! Link to post Share on other sites More sharing options...
adan Posted May 30, 2010 Share #5 Posted May 30, 2010 At any given subject distance, the 90 will always produce a larger image, right down to the minimum focus limit of .9 meters. Generally this is true through the range of focal lengths - given a fixed distance to the subject, the reproduction ratio/image size will be directly proportional to the focal length. The rule breaks down if one gets too close to "infinity" - either an infinitely short or infinitely long focal length - but a 14mm lens will make the subject 1/2 the size of a 28mm lens, and so on. As an aside - this (longer focal length + fixed subject distance = tighter framing) is true of all prime lenses, but not true for many modern macro-zooms. I was just playing around with a prime Leica 180 and a Sigma macro 70-200 f/2.8 on my Canon 5D. At 3 meters (10 feet) the prime 180 actually framed substantially tighter than the zoom at "200," which was framing like a 135. There was a thread about this recently - the effect has the silly name of "breathing" and just means that the zoom-makers achieve close-focus in a small package by modifying the focal length as well as the "focus" per se. But it can come as a shock if you are trying for a head-shot at a concert and expect your 200 or 300 zoom to frame the way your old prime 180 or 300 lens did at 3 meters. =:^o Link to post Share on other sites More sharing options...
