pgk Posted May 27, 2010 Share #1 Posted May 27, 2010 Advertisement (gone after registration) I have in front of me a 60mm Macro-Elmarit-R which appears to only have a third cam. I want to use it on a Bellows R and also on a 14158-1 tube for greater than 1:1 photography. However the mount is slightly different and it won't mount on either of these. Has anyone got any suggestions as to how it may be possible to use it? Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2010 Posted May 27, 2010 Hi pgk, Take a look here Using a 'Third Cam Only' lens on bellows. I'm sure you'll find what you were looking for!
wildlightphoto Posted May 28, 2010 Share #2 Posted May 28, 2010 A repair technician can modify the front flange of the bellows or extension tube to fit R-only lenses. It's a simple modification and not expensive. Link to post Share on other sites More sharing options...
pgk Posted May 28, 2010 Author Share #3 Posted May 28, 2010 Thanks Doug I'd started wondering whether this might be possible and the simplest option myself after looking very carefully at the bayonets yesterday evening - if I had one of the14158-1 female bayonets milled out it will probably solve all my problems. Off to the machine shop then. Link to post Share on other sites More sharing options...
wildlightphoto Posted May 28, 2010 Share #4 Posted May 28, 2010 Thanks Doug I'd started wondering whether this might be possible and the simplest option myself after looking very carefully at the bayonets yesterday evening - if I had one of the14158-1 female bayonets milled out it will probably solve all my problems. Off to the machine shop then. The lock pin might also need to be trimmed a bit, depending on its age. Earlier pins (Leicaflex-spec) are a larger diameter. Link to post Share on other sites More sharing options...
