Annibale G. Posted May 14, 2010 Share #1 Posted May 14, 2010 Advertisement (gone after registration) Hello, I've got a stainless stell tank for 8 reels. Showing it to my professional printer he's sad that Paterson ones are better for rotation. Usually with the other one same steel I used to turn upside down the tank 4 time every minute, he said the paterson have a their own system that allows not to invert the tank, that system is save from air bubbles and oxidation caused from invert upside down the tank. What do you think? I can still change this one back. What do you suggest me to do? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted May 14, 2010 Posted May 14, 2010 Hi Annibale G., Take a look here Darkroom Steel tank. I'm sure you'll find what you were looking for!
Xmas Posted May 14, 2010 Share #2 Posted May 14, 2010 Hi Some people have great trouble loading film into the Patterson spirals, and need to use 3rd party spirals or stainless spirals. If you drop a Patterson 8x tank, when it is full of liquid it is likely to be damaged, e.g. inversion and emptying, needs to be done with caution. I don't think this answers your question exactly. If you are to use the tank is its your choice. Noel Link to post Share on other sites More sharing options...
Annibale G. Posted May 15, 2010 Author Share #3 Posted May 15, 2010 It's not about loding the film into the spirals. It's just about agitation. As I said usually with the other one same steel I used to turn upside down the tank 4 time every minute, he said the paterson have a their own system that allows not to invert the tank, that system is save from air bubbles and oxidation caused from invert upside down the tank. What do you think? I can still change this one back. What do you suggest me to do? Thanks Link to post Share on other sites More sharing options...
Xmas Posted May 15, 2010 Share #4 Posted May 15, 2010 Sorry to appear equivocal. I use Patterson singles and multiples, some times I invert some times I use the twist rod, mainly I stand, never noticed any difference. If you are sure you can load the tank I'd go for the cheaper. Noel Link to post Share on other sites More sharing options...
Annibale G. Posted May 15, 2010 Author Share #5 Posted May 15, 2010 Again, it's not a matter about how much cost one or the other one. It's about quality results in terms of agitation. With the steel one I used to turn upside down the tank 4 time every minute, my professional printer said that paterson have a their own system that allows not to invert the tank; that system is save from air bubbles and oxidation caused from invert upside down the tank. What do you others people think about that? Link to post Share on other sites More sharing options...
Xmas Posted May 15, 2010 Share #6 Posted May 15, 2010 'Fine art' printing is very difficult to learn. But I'd recommend starting to learn or getting another pro printer. Noel Link to post Share on other sites More sharing options...
