40mm lens + 35mm Framelines w/out shaving lens?
piblondin
It's certainly possible, I'm just a little confused because the frame selector inside the body should just be going down, i.e. away from the flange. So, I'm not sure why it seems to be scraping now but wasn't when I went manually from 50 to 35 or 75 before I filed the flange. Odd!
Did you file the hook DOWN (IE toward the front of the lens) or BACK (in rotation around the lens)?
It should be filed around not down.
If filed down then the arm is dragging on it.
x
