28mm f/2 lens-ring w/aperture setting dot loose, moves ~15deg each way.
disambiguated
I'm experiencing a weird problem w/my 28mm f/2 lens - the foremost 'ring' of the lens, where the aperture setting dot is located, now has about 15 degrees or so of play in it, left-to-right.
Has anyone run into this before? The lens still seems to function and aperture setting is correct, even if the aperture dot is a bit cockeyed, but this obviously isn't optimal - especially as the hood for this lens is large, and having it sitting at an angle both looks dumb and can take up more space in the lower-right corner of the viewfinder.
Is this something an ordinary mortal can somehow fix, or does it require repair by a Leica lens specialist?
Clue greatly appreciated, many thanks!
Never mind, I figured it out - there are three tiny flat-blade screws on the foremost ring, and they'd somehow slipped loose. I simply aligned the ring properly so that the aperture dot was 90' vertical, then tightened each of the screws with a Philips Head 1.4 screwdriver, and that fixed it.
