Daniel Leung Posted April 4, 2010 Share #1 Posted April 4, 2010 Advertisement (gone after registration) Hi, Just curious to know. the 50mm F1 that I own is not coded. I heard that the F1 was original designed for film camera. the coding will minimize the vignetting as well as improve the white balance. is this true? it it worth it to send it to do the coding? Please advise Tks DL Link to post Share on other sites More sharing options...
Advertisement Posted April 4, 2010 Posted April 4, 2010 Hi Daniel Leung, Take a look here another coding question. I'm sure you'll find what you were looking for!
swamiji Posted April 5, 2010 Share #2 Posted April 5, 2010 It does not matter. Just select the lens from the manual list if you don't. If you use the lens a lot you can setup a profile. If it's your everyday lens, and switch between other coded lenses, then maybe. Link to post Share on other sites More sharing options...
