darkness30 Posted March 24, 2010 Share #1 Posted March 24, 2010 Advertisement (gone after registration) Hello, I am planning on developing slides at home by myself. I need books or webpages on how to do it. Thanks, Mehmet Link to post Share on other sites More sharing options...
Advertisement Posted March 24, 2010 Posted March 24, 2010 Hi darkness30, Take a look here Developing slides at home. I'm sure you'll find what you were looking for!
fotohuis Posted March 24, 2010 Share #2 Posted March 24, 2010 In principle no problem with the right equipment: Jobo CPA or CPP will do it with the right temperature accuracy. You can use Tetenal E6 or Fuji E6 chemicals. The whole procedure is according E6 standard so no deviations are possible according fixed times for all steps. Due the fact E6 is very critiqual in temperature you should use above mentioned Jobo processors. A small ATL machine is of course also possible. Link to post Share on other sites More sharing options...
Gift Posted March 24, 2010 Share #3 Posted March 24, 2010 Kodak has an E6 Kit for develope slides too. Easier than people usually thinks and I recomend a Jobo processor that you can find secon hand on the web. Just makes the work easy, but it's possible to devolope on a B&W developer tank just being very carefull with chemical and watter temp. It worth a try. Cheers. Link to post Share on other sites More sharing options...
