pre IIIf flash synch.
EJohnE
I had a IIc back in the 1950s, for which I bought an alternate shutter dial. That was cam-shaped, and was designed to make contact as it spun with a gadget to set off a flashlight. I remember using it with a Braun Hobby electronic flashlight. It is not the thing shown in the Wiki, but a rather larger gadget, and the cam was the dial, not a bit screwed on top. I had recently assumed that it was of Leitz make, but it may have been from some other manufacturer.
I may be floating in an amnesiac sea of confusion, but, dammit, I still have slides taken with that combination.
Any ideas?
John.
I think you have a IIc with a CMVOO. That was the code for the cam-shaped dials supplied by Leitz for use with the CAVOO flash unit. It was a basically cylindrical unit with a fairly large fan-folding reflector. It coupled by a special 'Vacu' synch unit that screwed on the shutter release and was operated by the rotating cam dial, which was supplied in different versions for different cameras. Your IIc should have taken a CAVOO-C. Synch speed was just 1/10 with long-peak flash bulbs, but there was also a Vacu for electronic flash. This Vacu, supplied separately, was the COOIF. Any bells ringing?
All this Rube Goldberg/Heath Robinson gear was supplied 1951-53 only.
The old man from the Kodachrome Age
It can be a Geiss one :
Thanks Lars and JC. It was not the Geiss one by the looks of it, but sounds like the COOIF as suggested by Lars. As it is over half a century since I used such a gadget, my sagging (soon to be 80 year old), "brain" may be excused for being so imprecise. If no-one is looking, I must confess that some enlargements I made during the '60s, show that I used my M2 to take them. I can't ever remember having an M2, although my right index finger has some residual sensation of resetting the exposure counter.
Confusion reigns, John.
