Codeing and RAW
markrune
I have an M8 with 50mm Sumitar (Coded) 90mm Tele Elmarit (Non Coded) and a 35 mm VM Color Skopar.
To be honest the 50mm and 90mm are used 95% of the time and I always shoot RAW apart from EXIF data would there be any benefits to getting the other lenses coded. I use UV/IR filters on all the lenses, and have not noticed any problems.
Thanks
Thanks but can anyone tell me if RAW files get adjusted by the coding, I know correction goes on for JPEGS, but can not see if it has any effect on DNG files, the manual is not clear (or I acan not see it). Certainly pictures seem to be fine.
Thanks but can anyone tell me if RAW files get adjusted by the coding.
The 6-bit coding tells the M8 how much in-camera correction should be applied to the data before it is written into the RAW file.
"After Leica applies all necessary corrections on the RAW data, such as vignetting correction and cyan correction, Leica then applies the Gamma LUT on the data."
http://kammagamma.com/articles/solving-the-leica-m8-dng-riddle.php
Personally, I'm really missing not having EXIF data written into the files with my uncoded lenses. Need to ship them off for CLA and coding.
Thanks!
Will
