Eisemann Posted January 16, 2010 Share #1 Posted January 16, 2010 Advertisement (gone after registration) Is there anything definitive regarding a forthcoming M8 Firmware update? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted January 16, 2010 Posted January 16, 2010 Hi Eisemann, Take a look here M8 Firmware. I'm sure you'll find what you were looking for!
samuco Posted January 16, 2010 Share #2 Posted January 16, 2010 today i got an email from leica where they mentioned 'the next update for the m8/m9' "The new update should be available soon. Please watch our homepage for the announcement." everyone will have his own interpretation of the leica 'soon' word sam Link to post Share on other sites More sharing options...
jlindstrom Posted January 16, 2010 Share #3 Posted January 16, 2010 Sweet! Hopefully we'll finally have the menu based manual coding for lenses in the M8 as well.. I've been putting off sending my 21mm back to Zeiss for mount change in anticipation of this. //Juha Link to post Share on other sites More sharing options...
Eisemann Posted January 16, 2010 Author Share #4 Posted January 16, 2010 I believe the menu additions will only effect the coding of the lens. You also need the mount that will pull up the 28mm frame line, which the menu options will not provide. Link to post Share on other sites More sharing options...
iwskipper Posted January 16, 2010 Share #5 Posted January 16, 2010 Yes, hopefully - the man. lens coding would be great! If not, I`ll send my cron 35 asph for coding to CS Regards JUS Link to post Share on other sites More sharing options...
jlindstrom Posted January 16, 2010 Share #6 Posted January 16, 2010 I believe the menu additions will only effect the coding of the lens. You also need the mount that will pull up the 28mm frame line, which the menu options will not provide. Hmm.. that would mean it'll still be a smart idea to use a template and black/white enamel to code the lens to avoid the hassle of changing the coding from the menu when swapping a lens. Guess we'll have to wait and see Link to post Share on other sites More sharing options...
Eisemann Posted January 16, 2010 Author Share #7 Posted January 16, 2010 Advertisement (gone after registration) You can forget the white, only the black is necessary. Should make hand coding a bit simpler. Link to post Share on other sites More sharing options...
jlindstrom Posted January 16, 2010 Share #8 Posted January 16, 2010 You can forget the white, only the black is necessary. Should make hand coding a bit simpler. Most of the times yes, but there are lenses where there's a screw in place of a white dot. Those have been known to be interpreted as black by the cameras coding sensor. So, at times white is also necessary. Well, that was a bit nit picking from my part but could be useful piece of info for someone not familiar with the procedure. //Juha Link to post Share on other sites More sharing options...
Eisemann Posted January 17, 2010 Author Share #9 Posted January 17, 2010 I stand corrected Link to post Share on other sites More sharing options...
