lars_bergquist Posted January 15, 2010 Share #1 Posted January 15, 2010 Advertisement (gone after registration) The picture was taken with my M9 and a borrowed 21mm Summilux, at f:1.4. But the EXIF says this is a v.4 35mm Summicron. Yes, I goofed -- but, I hope, in an instructive way. I had gone to the event (Stockholm Photo Fair, last November) carrying only one lens. You guessed it -- it was my old v.4 35mm Summicron. That lens was not coded, so I identified it via the lens menu. And then, in the excitement, I forgot switching to 'Lens recognition: Auto' after mounting that Summilux. But, strange to say, the roof did not fall in. There's nothing technically wrong with the picture. Now, I agree that the background is quite busy, but the result is nevertheless interesting. Maybe we should do some experimentation to find out just what disasters do occur -- or not -- when we inadvertently leave lens recognition at the wrong setting. (Admittedly, switching from a 90mm to the 21 'lux would probably not be a good idea.) Even so, I do still think mounting a coded lens should override the previous manual setting. The old man with the Flapping Ears and the Silly Grin Link to post Share on other sites More sharing options...
Advertisement Posted January 15, 2010 Posted January 15, 2010 Hi lars_bergquist, Take a look here Goofy Rides Again!. I'm sure you'll find what you were looking for!
adan Posted January 15, 2010 Share #2 Posted January 15, 2010 Actually - I've shot whole sequences with 21, 35, and 75 lenses while the camera stayed at "35mm Summilux" accidentally --- or at "28 Elmarit ASPH" while experimenting intentionally, and seen no horrible edge problems. Just the frustration of "bad" EXIF data, and a bit of extra vignetting from the 21 only. Which probably just goes to show that 28-35 corrections aren't very strong. Additionally, I've always thought the 21/24 'luxes were likely "digitally-friendly" designs - more telecentric - so they may not require as much correction as earlier 21/24 lenses, and the "amount" given for a 28 'rit or 35 'cron may be adequate. Obviously, as you note, Leica badly needs to produce a firmware upgrade to correct for busy backgrounds. Link to post Share on other sites More sharing options...
