M9 charger doesn't read "Done"
wparsonsgisnet
I am still using the M8 charger instead of the M9 charger because the M9 charger doesn't indicate when it's finished charging. That is, both lights just stay on.
With the M8 charger, the charging indicator turns off when it's done.
The manual has this (very brief) set of "instructions"
1.40 Green (CHARGE) LED to indicate charging
1.41 Yellow (80%) LED
Am I missing something?
Page 107 of my manual states (right below the picture of someone putting a battery into the charger):
The green LED marked CHARGE (1.40) starts flashing to confirm that charging is in progress. As soon as the battery has charged to at least 4/5 of its capacity, the yellow LED marked 80% (1.41) also lights up. When the battery is fully charged, i.e. 100% capacity reached (after approx. 31/2 hours), the green LED changes from flashing to continuously lit.
To be honest I know where you are coming from. I also keep expecting the lights to switch off too.
