hammam Posted December 16, 2009 Share #1 Posted December 16, 2009 Advertisement (gone after registration) Hi, Anybody has experience with the little FL-20 flash from Olympus on their M8? How does it perform? No voltage problem? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted December 16, 2009 Posted December 16, 2009 Hi hammam, Take a look here Olympus FL-20 flash and M8. I'm sure you'll find what you were looking for!
pklein Posted December 18, 2009 Share #2 Posted December 18, 2009 I got an FL-20 flash with "my other camera," an Olympus DSLR. The FL-20 is a great little unit. I always carry it with me because it's so small and light, and I use it now and then.. It works fine. I measured the trigger voltage, I think it was only about 5 volts. I've had no issues with the extra contacts (the ones other than the main flash trigger) causing any interaction. On the M8, the FL-20 works in manual and auto modes, but not TTL, of course. I've even used it as fill flash in manual mode. With the 1/180 or 1/125 second synch speed, 100 ISO and the right f-stop, you can take a picture in bright sunlight and illuminate your subjects that are shadowed. To lower the flash speed about a stop, use the old trick of a handkerchief over the flash. (A Kleenex tissue works, too). I prefer to not use flash unless absolutely necessary, and when I do use flash, I prefer to use bounce flash. I've got a couple of larger old flashes with bounce heads (and 8-12 volt trigger voltages) that I use most of the time when I actually plan to use flash. But the little Olympus FL-20 stays in my bag for those occasions when I didn't bring the big flashes and I need one. The guide numbers and f-stops to use in auto are approximate. Take a couple of test shots, check your histogram and adjust accordingly. Hope this helps! --Peter Link to post Share on other sites More sharing options...
hammam Posted December 18, 2009 Author Share #3 Posted December 18, 2009 Thanks, Peter. That's exactly what I need. With the holiday season, and all those family and friends reunions, it's good to have a little, light and unobstrusive flash for quick snaps. And a very merry Christmas to you. Link to post Share on other sites More sharing options...
