sbsatv Posted December 9, 2009 Share #1 Posted December 9, 2009 Advertisement (gone after registration) Help, I think I have done something to my If red dial. The shutter speed dial no longer matches the speed. I can still select different speeds, but the dial no longer matches the speed. I may have changed the speed without first cocking the shutter. Have I done any damaged, and how do I fix the dial to line up again? Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted December 9, 2009 Posted December 9, 2009 Hi sbsatv, Take a look here Help Leica If shutter.. I'm sure you'll find what you were looking for!
jc_braconi Posted December 9, 2009 Share #2 Posted December 9, 2009 Arm the shutter with the advance button, next unscrew a little bit the 3 screw around the speed dial till this last one turn not freely but quite, realign the speed with the index and retight the 3 screw. Link to post Share on other sites More sharing options...
sbsatv Posted December 10, 2009 Author Share #3 Posted December 10, 2009 Thank you sir, that seems to have solved the problem. I hope I didn't do any permanent damage. Link to post Share on other sites More sharing options...
