JPH1962 Posted December 8, 2009 Share #1 Â Posted December 8, 2009 Advertisement (gone after registration) Hello! Has anyone made experiences with these lenses on the M9: Â 18mm Super Elmar 18mm ZM Distagon 24mm Elmar 3.8 Â They are all certainly good lenses - but what about the currently existing issue with the red side? Â Can the 18mm ZM be corectly coded to be recognized directly as Super Elmar? Â Thanks for you opinion! Â rgds JPH Link to post Share on other sites More sharing options...
Advertisement Posted December 8, 2009 Posted December 8, 2009 Hi JPH1962, Take a look here M9 with 18 & 24mm Leica / Zeiss ZM. I'm sure you'll find what you were looking for!
thechief Posted December 8, 2009 Share #2  Posted December 8, 2009 Hello! Can the 18mm ZM be corectly coded to be recognized directly as Super Elmar?  Thanks for you opinion!  rgds JPH  Hi, I have no experience using this lens with Leica M9 however with Leica M8.2 it is great lens. Firstly, I have tried to code this lens as Super Elmar but it was not recognized by camera, then coding was applied as WATE, it's work, only need further 18mm confirmation at camera menu which automatically appears upon camera switching on. Link to post Share on other sites More sharing options...
Ario Arioldi Posted December 8, 2009 Share #3 Â Posted December 8, 2009 Hi,I have no experience using this lens with Leica M9 however with Leica M8.2 it is great lens. Firstly, I have tried to code this lens as Super Elmar but it was not recognized by camera, then coding was applied as WATE, it's work, only need further 18mm confirmation at camera menu which automatically appears upon camera switching on. My ZM 18 triggers the 50/75 frame lines and as such can be coded as SuperElmar 18. To code it as WATE you need a bayonet which triggers the 28/90 frames which is not my case. Having said that my experience with M9 is that none of the available codes (either manually set or auto) is actually giving satisfactory result and therefore, with the present FW, I prefer to use CornerFix to correct vignetting and color shift. Cheers, Ario Link to post Share on other sites More sharing options...
JPH1962 Posted December 8, 2009 Author Share #4 Â Posted December 8, 2009 Thanks so far for the ZM - any experiences with the 18 Super Elmar and the 24 Elmar around? Â rgds JPH Link to post Share on other sites More sharing options...
chris_tribble Posted December 8, 2009 Share #5 Â Posted December 8, 2009 Having said that my experience with M9 is that none of the available codes (either manually set or auto) is actually giving satisfactory result and therefore, with the present FW, I prefer to use CornerFix to correct vignetting and color shift. Cheers, Ario Similar experience with the ZM - codes as the Super Elmar 18mm, some small red-shift issues, but easy to fix with Lightroom colour gradient filter (alternative to CornerFix... ) Â See discussion here: Â http://www.l-camera-forum.com/leica-forum/leica-m9-forum/108078-m9-lenses-red-edge-problem.html#post1140980 Link to post Share on other sites More sharing options...
Balivernes Posted December 8, 2009 Share #6  Posted December 8, 2009 Thanks so far for the ZM - any experiences with the 18 Super Elmar and the 24 Elmar around? rgds JPH  Have and love the 24 Elmar/M9. No unwanted red smears anywhere! Link to post Share on other sites More sharing options...
markowich Posted December 8, 2009 Share #7 Â Posted December 8, 2009 Advertisement (gone after registration) Hello!Has anyone made experiences with these lenses on the M9: Â 18mm Super Elmar 18mm ZM Distagon 24mm Elmar 3.8 Â They are all certainly good lenses - but what about the currently existing issue with the red side? Â Can the 18mm ZM be corectly coded to be recognized directly as Super Elmar? Â Thanks for you opinion! Â rgds JPH Â i use the super elmar 18mm on the M9 and have absolutely no issues with it. no red corners and no infinity focus problem (which have been reported here). there seems to be sample variation. mine is wonderful. peter Link to post Share on other sites More sharing options...
scottwallick Posted December 9, 2009 Share #8 Â Posted December 9, 2009 Have and love the 24 Elmar/M9. No unwanted red smears anywhere! Â Thanks for sharing this, too. I'm planning on picking up the Elmar/3.8 here after New Year's. Link to post Share on other sites More sharing options...
