steve70 Posted December 4, 2009 Share #1 Posted December 4, 2009 Advertisement (gone after registration) Hello, I am a bit new to digital, or at least rather new to the new iMac I just purchased. I also purchased a new M9, so I installed, or so I thought the free Light Room from this Leica Owner's site. Well, I downloaded it, but every time I try and bring it up, it wants to re-install it's self. What the heck am I doing wrong? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted December 4, 2009 Posted December 4, 2009 Hi steve70, Take a look here Help with Light Room. I'm sure you'll find what you were looking for!
Guest WPalank Posted December 4, 2009 Share #2 Posted December 4, 2009 Steve, You are probably still accessing the installer that is probably still on your desktop. Find your Applications Folder and launch it from there. It should be listed alphabetically as "Adobe Light Room 2". Link to post Share on other sites More sharing options...
Jeff S Posted December 5, 2009 Share #3 Posted December 5, 2009 ...and read this book before you get too far...Amazon.com: The Adobe Photoshop Lightroom 2 Book for Digital Photographers (9780321555564): Scott Kelby: Books Jeff Link to post Share on other sites More sharing options...
chris_tribble Posted December 5, 2009 Share #4 Posted December 5, 2009 ... and check out Michael Reichman and Jeff Schewe's tutorials on Luminous Landscape... Link to post Share on other sites More sharing options...
ronaldh Posted December 5, 2009 Share #5 Posted December 5, 2009 I have the following problem with LR 2.5 which until recently I was using without any trouble. All the folders in the library have lost their names and just show question marks where the names were. If I right-click (I use a pc) then click "find missing folder" a warning pops up stating that the file or folder is already in Lightroom, but when I go into the develop module and select one of the files LR tells me that the file is offline or missing. I thought this might have arisen because I downloaded LR3 beta, so I uninstalled that but it has made no difference. Can anyone help please? Link to post Share on other sites More sharing options...
Jeff S Posted December 6, 2009 Share #6 Posted December 6, 2009 I have the following problem with LR 2.5 which until recently I was using without any trouble. All the folders in the library have lost their names and just show question marks where the names were. If I right-click (I use a pc) then click "find missing folder" a warning pops up stating that the file or folder is already in Lightroom, but when I go into the develop module and select one of the files LR tells me that the file is offline or missing. I thought this might have arisen because I downloaded LR3 beta, so I uninstalled that but it has made no difference. Can anyone help please? I wonder if you disconnected an external drive at some point. In any event, once you right click on the folder and choose "find missing folder," then you should be able to navigate to the folder's new location and click "select" to relink. (At least, so says Mr. Kelby.) Jeff Link to post Share on other sites More sharing options...
wda Posted December 7, 2009 Share #7 Posted December 7, 2009 Advertisement (gone after registration) I have the following problem with LR 2.5 which until recently I was using without any trouble. All the folders in the library have lost their names and just show question marks where the names were. If I right-click (I use a pc) then click "find missing folder" a warning pops up stating that the file or folder is already in Lightroom, but when I go into the develop module and select one of the files LR tells me that the file is offline or missing. I thought this might have arisen because I downloaded LR3 beta, so I uninstalled that but it has made no difference. Can anyone help please? You will often find files with "?" marks. Clicking on the ? will invite you to refresh the link. But folders usually show in pale letters until the folders are on-line. One other thought, try accessing a recent backup of your LR catalogue. Sometimes they can get corrupted. Link to post Share on other sites More sharing options...
spylaw4 Posted December 8, 2009 Share #8 Posted December 8, 2009 You will often find files with "?" marks. Clicking on the ? will invite you to refresh the link. But folders usually show in pale letters until the folders are on-line. One other thought, try accessing a recent backup of your LR catalogue. Sometimes they can get corrupted. It is also a good idea to set LR to do a backup and a Catalogue check regularly - once a week say. I think ronaldh has for whatever reason moved the missing files to another location - the cure has already been given here. The Op is indeed trying to access via the installer. Once installed delete the unzipped installer, but retain the downloaded original dmg somewhere in a folder for software downloads. Link to post Share on other sites More sharing options...
ronaldh Posted December 8, 2009 Share #9 Posted December 8, 2009 Thanks for your suggestions. It is not for want of a back up, but I have noticed that what was Drive H on my pc is now called Drive I and what was I is now J. Both are external drives but I have done nothing to change any connections so remain mystified and also wonder if this is linked to the LR problem. Ronnie Link to post Share on other sites More sharing options...
chris_tribble Posted December 14, 2009 Share #10 Posted December 14, 2009 Windows assigns drive letters to external drives when they're turned on - it's not a permanent attribute. If you've added a drive, then letters will be re-assigned. Not a problem - in Lightroom simply browse for the re-located folder and everything will be updated. Link to post Share on other sites More sharing options...
