jackal Posted November 14, 2009 Share #1 Posted November 14, 2009 Advertisement (gone after registration) hi guys on my m8 through the VF, the shutter speed numbvers appear very blurred unless you kind of lower your eyeline (by which point the numbers tend to disappear behind the lower edge of the viewfinder) is this a known problem ? regards J Link to post Share on other sites More sharing options...
Advertisement Posted November 14, 2009 Posted November 14, 2009 Hi jackal, Take a look here shutter speed display blurred ?. I'm sure you'll find what you were looking for!
gwelland Posted November 14, 2009 Share #2 Posted November 14, 2009 This isn't meant to be sarcastic: Assuming that everything focusses clearly and easily then, it could be as simple as being slightly far sighted ... Link to post Share on other sites More sharing options...
jackal Posted November 14, 2009 Author Share #3 Posted November 14, 2009 no its not that because my M9 works just fine Link to post Share on other sites More sharing options...
Steve Ash Posted November 14, 2009 Share #4 Posted November 14, 2009 Most likely the mask went out of place. You need to give it a technician. Regards Steve Link to post Share on other sites More sharing options...
jackal Posted November 14, 2009 Author Share #5 Posted November 14, 2009 ok thanks steve can you explain this mask a bit more ? Link to post Share on other sites More sharing options...
jackal Posted November 14, 2009 Author Share #6 Posted November 14, 2009 took another look its not that its blurred rather that you see a double or triple image of the display so virtually unredable Link to post Share on other sites More sharing options...
gwelland Posted November 15, 2009 Share #7 Posted November 15, 2009 Advertisement (gone after registration) If your M9 is fine but the M8 is out then something's obviosly in need of adjustment. As steve mentioned, it could be that the RF mask or the RF in general has something out of alignment so best to get it looked at by Leica or one of the other Leica specialists. Link to post Share on other sites More sharing options...
