Sean Reid's X1 Part 2 Review is up
c6gowin
Dear Sean,
How much faster is the AF in the GF1 than in the LEICA X1 in absolute figures (secs) ?
Will the GF1 be more close to DSLR AF or still nearer to standard P&S speed but just a tad faster ?
Thanks again in advance
Hexar
I do not have the necessary equipment to measure that in absolute specs. One would need proper equipment and would need to test under a variety of different conditions. Photographing a stopwatch on screen only covers one kind of lighting condition.
I still need to do the file quality/ISO comparison tests for the X1, DP2 and GF1 but then I need to concentrate on the S2. I also have major surgery coming up (would prefer not to go into details about that) and so will need to take some time away from camera testing in December.
Cheers,
Sean
  • Replies 311
  • Created
  • Last Reply
Thanks Sean.
What is your preffered ratio 3/4 or 2/3 ?
The view of field between the 20mm on the GF1 in 3/4 ratio does differ from the 35mm in 2/3 that much as it would be in both 2/3rds would it ? both focal lengths in 2/3 make a bigger difference and that`s why we should not compare the LEICA X1 35mm with the 20mm Pana in the way we would with similar camera`s as far a field of view is concerned. Anything to this from your point of view ?
Best regards
Hexar
Should read
The field of View between the 20mm on the GF1 in 3/4 ration does NOT differ etc etc
Sorry to fast writing on a sunday..
Hallo Sean,
Is there a way to lock AF and not exposure at the same time ? I am still strugling with the fixed AF without having to get a fixed exposure. So I point my camera (X1) to a subject at let`s say 4 metres and then want to take an other subject with keeping the AF locked on this 4 metres but with automatically get new exposure.
(sort of AF LOCK feature)
Thanks
Hexar
Hallo Sean,
Thanks
Hexar
If you focus to a spot using AF and then change to MF then the camera preserves its focus distance. Now you can move the camera and recompose with a new exposure and preserve the focusing distance . The question is how fluid is it to shift to MF from AF and then back for the next picture? Not the best solution I admit.
For zone focusing this could be very useful; simply AF to a spot and shift to MF for subsequent series of pictures; no need to fuss with the on screen distance scale.
Take care!
Furrukh
Hallo Sean,
In the dpreview I found the following AF setting:
The 'H' modes are 'High Speed', which focus faster but at the expense of a momentary freeze of the live view display.
What about this. Did you try this setting and what is of any help in speed ?
Regards
Bert
An example to use this technique would be to shift to F8 ( in good lightning conditions) AF at a point at 4 metres for example and you can shoot very fast ahead between 2 metres (1.9 metres exact) and infinity without having to worry about AF speed , shutter lag .
A good way to work with a camera like the LEICA X1 but again you have to know what you are doing. (or/and experiment a lot)
I just had an other look at the dials on top of the X1 and see that in order to shift to Manual mode you have to turn a tiny ring around the shutter button, WIll this be possible at all when yoiu have the shutter button pressed half way to lock AF ?
I looks a bit awckward but maybe someone can tell me the practice here.
I believe you toggle between AF and MF like this:
Press the AF/MF button embedded within the wheel (right lower part of the back); turn the wheel to select AF or MF from a short menu. I believe the menu has only two selections; saw it somewhere in some review. So perhaps turning the wheel one way takes you to MF and the other way to AF; if that is the case then the process can be somewhat fluid.
Take care!
Furrukh
Thanks,
Maybe Sean can help us out here how it is done most fluidly. MF modes are obviously very important in this camera so this point should be quit clear to me.
Regards
Hexar
According to online reviews the AF/MF menu has three selections; AF, AF Macro and MF. If the menu is not cyclical then switching between AF and MF could be done without looking at the menu provided AF and MF selections are at the opposite end with AF Macro in the middle; if it is cyclical then one will have to rotate the wheel carefully. I am sure Sean will make this clear after he has recovered from all the dessert intake at the wedding.
Take care!
Furrukh
Hallo Sean,
Regards
Bert
Yes, I discussed that in the review.
You've read the review already, right? If yes, you might want to reread it to clear up some of these details. That switch has nothing to do with manual focus mode - fortunately.
Cheers,
Take care!
Furrukh
Hi F,
If you reread the review you'll note that one can cycle through the focus settings (AF/MF/AF macro) with just repeated presses of the AF/MF button. No need for the wheel unless desired.
Cheers,
Sean
Hi F,
Cheers,
Sean
Yes, now I do recall reading that in your review; I even made a note of that for myself :) This is excellent. So the cycle goes like:
AF, MF, AF macro, AF, MF, AF macro
So if you are in AF then one press takes you to MF and if you are in MF then two presses take you to AF. Going from AF to MF locks the focus distance. One can do this without looking at the screen or rotating the wheel which is very nice!
Take care!
Furrukh
Hi F,
Cheers,
Sean
Sorry, I must correct this. The order is actually AF/AF Macro/MF.
Cheers,
Sean
Take care!
Furrukh
Hi F,
See the corrected oder above (my mistake in the earlier post) but yes this can all be done with presses of that one button.
Cheers,
Sean
