Nikon Sb-28 Flash on Leica M8 in Manual Mode
Jiukuic5609
x
Dan, I have no experience with the SB-28 and little experience with Nikon flashes, so take the following as a starting point:
A) Use the forum's search function; I think I've seen this topic before.
B) Recent flashes use a low trigger voltage. Some flashes from 20 years ago had a high enough voltage that they could destroy the electronics of later cameras. (I think the SB-28's trigger voltage and polarity fall into the 'safe' category. For example, SB-800 is safe on the M8.)
C) If you're worried about point B, Wein offers a range of "Safe-synch" shoes to avoid any incompatibilities.
D) If the SB-28 allows manual operation and doesn't need any information from the camera except the "fire" signal, it should work fine (i.e., no ISO sensing, no aperture sensing, etc).
E) If the SB-28 allows the simple, built-in flash automation that preceded TTL and CLS and all today's feedback mechanisms, that should work as well on-camera, and in some situations off-camera.
And if you're lucky, someone who knows what he's talking about will pipe up. :)
