IcoLove Posted October 29, 2009 Share #1 Posted October 29, 2009 Advertisement (gone after registration) Heya I have come into a winfall of a bunch of rolls of Kodak EIR Color Infared Film. Is this stuff ok in an M4-P and M7? Any Special Precautions? Thanks! Craig Link to post Share on other sites More sharing options...
Advertisement Posted October 29, 2009 Posted October 29, 2009 Hi IcoLove, Take a look here Kodak EIR Color Infared . I'm sure you'll find what you were looking for!
tgray Posted October 29, 2009 Share #2 Posted October 29, 2009 Should be fine. Load in darkness. Make sure you get it developed in darkness too - no IR lights. Keep it cold too. Link to post Share on other sites More sharing options...
aesop Posted October 29, 2009 Share #3 Posted October 29, 2009 ...hey, Craig, there should be no problem with using IR film with the M4-P body. This is not necessarily the case with the M7 body - if your M7 has the newer IR optical DX reader (as opposed to the old-style DX reader with spring-loaded contacts), this could affect IR film. Perhaps some other more knowledgeable forum member could add to this point. With specific regard to using IR film with the M system, the fact that IR radiation differs from visible radiation in wavelength means focusing is not straightforward as with "regular" film. Click on this previous thread for further details on this issue. Hope this helps. Let us know how you get on. Link to post Share on other sites More sharing options...
tgray Posted October 29, 2009 Share #4 Posted October 29, 2009 Color IR shouldn't have the issue of focusing as long as you aren't blocking all visible wavelengths. The visible parts of the image will be correctly focused. The IR might be a bit out, but two colors out of three in focus should be fine. As far as the M7, I've had no problems using HIE in my camera with the optical DX contacts. I'm pretty sure HIE is more IR sensitive than EIR, so you should be fine. Link to post Share on other sites More sharing options...
IcoLove Posted October 30, 2009 Author Share #5 Posted October 30, 2009 Thanks for the tips guys. Hopefully the film will still give good results! Link to post Share on other sites More sharing options...
tgray Posted October 30, 2009 Share #6 Posted October 30, 2009 Yeah, I have like 18 rolls of the stuff left. The first two came out very messed up. I'm not sure if it as because the film was bad, I left it in the camera too long in bad weather (1 week during the summer), or if the lab processed with IR lights. The rolls were all red except for the last frame or two. Link to post Share on other sites More sharing options...
