DLUXIOUS4 Posted October 21, 2009 Share #1 Posted October 21, 2009 Advertisement (gone after registration) I just got my DL4 yesterday.. I know there is a firmware update 1.2 -- I downloaded the file, extracted it, copied the extracted BIN file to my SD card to the 'main root" together where the DCIM folder is and another folder-- so with the extracted file -- there would be 3 folders. Inserted the SD card to my camera..on play mode, turn it on.. but it says "no valid picture toplay'... accdg. to the instructions.. when that appears-- use the camera as is... I have firmware 1.1 is my DL4 upto date? or do I update it to 1.2? and if I do what am I doing wrong in updating the firmware. thanks.. Link to post Share on other sites More sharing options...
Advertisement Posted October 21, 2009 Posted October 21, 2009 Hi DLUXIOUS4, Take a look here DL4 firmware 1.1 or 1.2?. I'm sure you'll find what you were looking for!
john_newell Posted October 21, 2009 Share #2 Posted October 21, 2009 there would be 3 folders At least on a PC, what you should see is two folders and a file, not three folders. If you're using a Mac, I can't tell you what exactly you should see. Link to post Share on other sites More sharing options...
DLUXIOUS4 Posted October 21, 2009 Author Share #3 Posted October 21, 2009 thanks... i got it... :-) Link to post Share on other sites More sharing options...
john_newell Posted October 22, 2009 Share #4 Posted October 22, 2009 Very good. Assuming it's like the LX-3, the other trick is that you need to start the camera up in playback mode. Link to post Share on other sites More sharing options...
