Vuescan question
ian moore
I use a Nikon Coolscan 5000ED for scanning with Nikon Scan software. I simply scan to get the highest resolution image (4000 ppi) and then import into Photoshop for usual curves,tonal,colour and sharpening. I use Neatimage for noise reduction,if required (negatives usually).
I rarely use the Nikonscan software for any adjustments,maybe global black/white points setting,and some analog gain and thats it.
Is it worth changing to Vuescan when I really only scan to get a high resolutuion image and nothing else?
Any views?
Ian.
Not if you are only doing color. I like Vuescan for traditional B&W, but any C-41 or slide film gets run through Nikonscan. Vuescan doesn't do ICE very well in my mind. Technically it doesn't do it at all but there's a crummy dust reduction feature which uses the scanner's hardware. Also, the colors tend to look funky to me.
For B&W though, Vuescan lets me get scans that aren't clipped at all, and lets me scan fast. I personally scan a lot of B&W film, not at full resolution, and that always seems to go way quicker in Vuescan than it does in Nikonscan.
If Nikon Scan works on your computer, there is no need to use Vuescan, if you do all the PP in Photoshop. If you're on a Mac, and Nikon Scan crashes all the time, than Vuescan is for you.
That is indeed a good reason to use VueScan. Nikonscan runs fine on the 2 macs I've used it on though.
The great thing about Vuescan is it was $60(?), which gives you an license for any kind of computer (mac, PC, linux) for any scanner. The man updates the program like every 20 minutes too.
