Leica M9 or M8 tethered usage
Guest BigSplash
Guest BigSplash
I have been reading that top Canon and Nikon DSLR's can be used in a tethered mode, such that as each image is taken it drops directly to a PC hard disk while presumably triggering a flash unit if used. I wonder if this can be done with the M9 or M8 via the PC port? Also when pros use the camera in tethered mode do they use a cable interconnect or a blue tooth (or similar) adapter? Any feedback most welcome. Thanks
