Showing results for tags 'view finder'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. While using M11-P today with a 28mm and 35mm lens, I noticed that top line frame looks obstructed not continuous. Also noticed that the digital display looks kind out of focus. I check with another unit M10R and the lines are continuous and the digital display looks in focus. on the 50mm I do not see this issue. I checked the lens were correctly connected and also while manually adjusting the bayonet, I can also see the issue with the 28mm and 35mm line. It may require service but want to check if other have seen this and if this may be a common issue. The attached picture is for viewfinder with the 28mm line frame. Thanks Wal III... IMG_8806.HEIC
