Showing results for tags 'two cl bodies?'.
Found 1 result
  1. Wondering how many of you have two current CL bodies? Is it overly too luxurious to have more than one CL body? When using the R & M systems before, it was a norm to bring along two R bodies, or two M bodies for different lenses, and for surety of in case one body had problem. But nowadays with the digital bodies, not only way too expensive to purchase at new, it is also worthless in few year... However when thinking of two bodies' convenient shooting without changing lenses, a surety of won't be out of camera body if one fails. e.g. one CL with a 23mm TL lens, another one with a 50/f1.4 M lens... However, considering the points above mentioned, is it too much to have two CL, how many of you have two CL? Would you rather to put the cost of "second" CL body on another TL lens, or go for the double CL bodies, which would increase the usages of the already own lenses?
Γ—
Γ—
